FOR SALE Brand NEW 471 stroker 400 mopar big block engine
Gene C
10:41 AM
long island NY
Guys have the best big block stroker deal for you. Its a 471 cu inch 400 block with stroker crank Ross pistons,Manley rods,arp all the best parts all new,over 10,500 in parts 2,500 in machine work,from custom 471 Air cleaner,875 Demon race carb,1 inch spacer,M-1 intake cnc'd 906 heads 3/8 custom pushrods,Rockers,Ferrea valves,Mopar performance v/covers,billet double chain and gears Torrington bearing SFI damper,aluminum electric waterpump pullys,arp bolts custom bearings hemi oil pump and pic-up with 7qt pan,windage tray plugs,wires distributor 250.00 MSD coil,over 10,500 in parts and 2,500 in machine work done by ACE Crankshaft NY depending on what cam you choose it will run on pump gas 625 to 725HP this thing needs nothing you would have to spend 14,500 for everything I have with out race carb,electric w/p distributor wires oil plugs damper pulleys it would cost 12,500 I'm ready to sell to First 7500 or best officer pump gas engine the only part not chosen is the camshaft HYD 625-640HP Solid cam 640-675HP solid roller 725hp but willneed 700 extra for special springs,billet cam and roller rockers Make me an offer been building engines for 25yrs my last SBC had 645hp pump gas that cost 9500,still running 10.52 at ATCO Racway with 9 inch slicks 3.55 gears and getting 13mpg just call Ray Barton,or Hughes Bros and ask them how much they want for a compleat 625hp hyd 471 stroker or how much for a 675hp for a solid cam 471 plus this thing is going to rev like a 302 chevy with over 30-40lbs removed from the rotating assembly call 631-585-8228 make me an offer no insults 7500 is half pricenever turned over call me currently building an LS-6 for my 2001 SS Camaro SUPER DEAL......
pics please.
