copperstate68
New Member
I made a rookie mistake and managed to break 2 wheel studs off on one corner. This almost certainly happened because the the combination of new wheels and lug nuts I had just put on had been loosening themselves up and frankly I forgot to keep checking on them until I heard sounds while driving and got out and only had 2 lug nuts left on one wheel!
So anyways, I went to replace the broken wheel studs and was going to do all 5 while I was at it. First, I tried one of the ones that didn't break and it came right out with a few taps with a hammer with a wood block behind.
The two broken wheel studs I cannot get to come out. I've gone through a bunch of the threads here and elsewhere and gotten a lot of ideas, but so far haven't had any luck-
* hammer + wood block
* 5 lb hammer + wood block
* tie rod end removal tool to push it through
* clamp + socket on the back
* drilling through the stud
* grinding off the head of the stud trying to push it through the other way with a 5lb hammer with a center punch in the hole I drilled. This did budge it ever so slightly after a lot of pounding (see pics)
At this point I'm not sure if there is any hope of getting these out.. or if I do finally get them out if the splines will be destroyed. I have the axle shaft out of the car and am not opposed to taking it in somewhere that has a press and see if they can press it out if you guys think it's worth continuing to try to get the studs out.
If the studs won't come out nicely, I'll need to replace the axle shaft, is that correct?
FWIW, this is a 68 charger, 8 3/4" rear end
