The Rebel
Spent 3/4 of the day at work (it's dead slow right now) researching & trying to decode my build sheet. Here's what I've come up with. Anything in RED I need your help with but if you see any other glaring issues let me know.
Thanks in advance,
Roger
Sequence Number: 2064455 What does this mean?
Shipping Order
122 Scheduled Production Date: Monday January 22, 1968
063290 Shipping Order Number What does this mean?
Vehicle Identification Number
XP Car Line: Dodge Charger
29 Body Type: 2 Door Sports Hardtop
H Engine: 383 1-4 Barrel HP “B”
8 Model Year: 1968 “D-Series” What does this mean?
H Assembly Plant: Hamtramck, MI (Dodge Main).
265809 Assembly Plant Sequential Number. As I understand it each plant started numbering at 100001, so this means my car was the 165808th car to roll off the assembly line?
Paint & Style
P Roof Color: Red
P Body Color: Red
291 Paint Style/Stripe: Mono Tone Paint
B Upper Door Frame Paint: Black
306 Vinyl Roof: Black (extra cost)
C Trim Grade: Charger
6 Front Seat: Vinyl Bucket
X Trim Color: Black
62 Engine: 383 1-4 Barrel HP 330hp. According to the codes does this mean a 3-speed automatic was single exhaust? Something doesn’t seem right.
395 Transmission: Torque Flite Automatic
404 Axle: 3.23:1 Ratio
415 Heater: Front with Defroster
421 Radio: AM Music Master/Economy (2W)
Tires
33 7.35 x 14 White Wall Tires, Steel Belted (Extra Cost).
Power Equipment
451 Power Brakes
456 Power Steering
480 Dual Horns
483 Bumper Guards: Front & Rear
484 Electric Clock
486 Console
487 Cigar Light – Front
503 Floor Mats or Carpets
509 Glove Box Lock
Lights
515 Ash Receiver Light. What does this mean?
517 Hood Mounted Turn Signal Indicator
522 Tinted Windshield Only – Blue Shaded
536 Left Hand Outside Remote Control Mirror
Moldings
535 Drip Rail Molding
540 Belt Line Molding
548 Wheel Lip Molding
564 Bucket Seats
565 Rear Armrest & Ash Tray
584 14” Deep Dish Wheel Covers
589 3-Speed Wipers
627 59 AMP/HR Battery
624 Heavy Duty Suspension with Sway Bar
SPL Codes
691 Expedite (Sold Car When Built, Somebody Ordered It).
Fleet Items
647 Heavy Duty 14” Wheels
Build Codes
66 Vac. F/T.:
5 Sway Bar: .94” Link Type (Late Model)
45 Radiator: 22” 383/440 w/AT “B” Body
708 Engine:
031 Transmission: Late A727B For A 383-4
237 Axle: 8 ¾ With 3.23 Ratio and 10” Drums
32 Pinion:
16B Wheel:
79 Wheel Covers:
62 Propeller Driveshaft: 7290 Type *2
779-778 Torsion Bar L/R: 41” x .90” *3
211-211 Rear Springs L/R:
42 Clutch & Brake Bracket:
22 Front Brake:
67 Front Shock:
93 Rear Shock:
62 Battery: 59AMP For 383, With Yellow Caps A24-B Series
36X Steering Column:
12X Steering Wheel & Horn Ring:
15 Stub Frame: 68 B Body With 273, 318, 383 And 440 All With AT
24 Engine Fan: 18” 7-Blade For 383/440 *4
32 Fan Spacer: 1.24” For 383/440 *5
01 Radiator Inlet Hose:
31 Radiator Outlet Hose: B/C/D Body With 361, 383 or 440
01 Carburetor: 383 Auto AVS With AT *6
45 Carb. Choke: 68-69 383-4/440-4 Carter AVS (A/B/C Body)
42 Cap Idle Label: Is this the last 2 digits of the emission decal for big block automatics that went in front of the washer reservoir on passenger inner fender?
R: 52
*1 The assembly plant sequential number is set to 100001 every new model year. Your car is the 138753rd built at the St. Louis assembly plant.
*2 More detailed information regarding the propeller driveshaft (Code: 62):
Type: 7290
Diameter: 3.00”
Length: 52.07”
Transmission: Both
Axle: 8 ¾
Model: WX
Engines: 383, 426 and 440
U-Joint Type Diameter is measured inside the yoke: 7290 = 2 5/8”
*3 More detailed information regarding the torsion bars (Code: 779-778):
Year-Year: 1962-1969
Body: B-Body
Engine: 383-4
Length: 41”
Diameter: .90”
Paint: Aluminum
*4 More detailed information regarding the engine fan (Code: 24):
Year-Year: 1968-1971
Body: A/B/C/E Body
Engines: 383 and 440
Blades: 7
Heater/A/C: Heater
Diameter: 18”
Points: 2”
*5 More detailed information regarding the fan spacer (Code: 32):
Year-Year: 1967-1969
Body: B/C Body
Length: 1.24”
Heather/A/C: A/C
*6 More detailed information regarding the carburetor (Code: 01):
Engine: 383 cubic inch V8
Transmission: Automatic
Type: AVS
Model: BLRWXPDC
Remarks: HP Engine
Carburetor Number: 4401S
Thanks in advance,
Roger
Shipping Order
Paint & Style
P Roof Color: Red
P Body Color: Red
X Trim Color: Black
Tires
Power Equipment
451 Power Brakes
456 Power Steering
480 Dual Horns
484 Electric Clock
486 Console
509 Glove Box Lock
Lights
Moldings
564 Bucket Seats
589 3-Speed Wipers
SPL Codes
Fleet Items
Build Codes
66 Vac. F/T.:
708 Engine:
32 Pinion:
16B Wheel:
79 Wheel Covers:
22 Front Brake:
67 Front Shock:
93 Rear Shock:
R: 52
Type: 7290
Diameter: 3.00”
Length: 52.07”
Transmission: Both
Axle: 8 ¾
Model: WX
Body: B-Body
Engine: 383-4
Length: 41”
Diameter: .90”
Paint: Aluminum
Body: A/B/C/E Body
Blades: 7
Heater/A/C: Heater
Diameter: 18”
Points: 2”
Body: B/C Body
Length: 1.24”
Heather/A/C: A/C
Type: AVS
Model: BLRWXPDC
Remarks: HP Engine
