May have to go exploring. I found a couple roaming a junk yard.Thank you!
I also need tire iron and hook.
The hook is easy to identify with the stamped number but what about the tire iron? What should I look for to get a right tire iron that match the jack?
If you have an iron of right type I’m interested!May have to go exploring. I found a couple roaming a junk yard.
Will look and see if I can locate one this weekend. Will PM you.If you have an iron of right type I’m interested!
ThanksWill look and see if I can locate one this weekend. Will PM you.
