chargin'
I'm soon going to install the rear glass in my '69 Super Bee. How do you feel about or any pros or cons to using either butyl tape or urethane? It doesn't need to be done how the factory did it for originality reasons.
Thanks for all the reply's,I'm leaning toward the butyl tape,afraid about the depth for the molding to fit nice.
Thread hijack.
Sort of.
So his 69 Bee doesn't use a rubber gasket?
It just sits on the body?
I'm going to do a 67 Charger and when I pulled the old rubber out it had plenty of non-setting butyl under the rubber.
It appeared to be tape.
I know I should put the new rubber on the glass, insert rope/string in the grove, lay it in the hole and pull the inner lip in and over the fence from inside the car.
But other than putting very little butyl around the very edge of the rubber prior to installation, I can't see how in the world Chrysler got that much butyl under the original rubber unless they injected it after installation?
In other words, I can't see the tape staying in place as the rope is pulled.
Am I missing it?
Anyone know?
