Garys1969RR
I have 2 69 Roadrunners now. The first one has a 451, 13 to 1 C/Ratio, Holley street dominator with Holley 850 dbl pumper, Auto trans, 509 cam. 3.91 gears. Runs consistent 12.50 at 110 MPH. (5600 feet) Cranking compression is around 220 PSI. Runs on 98 octane fuel. The second one is the same except, 11 to 1 C/Ratio, 440, Performer RPM intake, Holley 3310, 780 CFM, 4.11 gears, Solid lifter cam. 180PSI cranking compression. Runs fine on 91 pump gas, Runs consistent 13.70 at 100 MPH. Not sure what the cam specs are, but it has a smoother idle than the 509 cam has. The Hi Compression 451 has a much stronger sound to it than the 440 does. So very similar built cars/motors except for C/Ratio. I have found that the higher compression motors produce WAY more power than the ten and eleven to one C/R motors do. I always like the higher C/R motors.
The 2 points higher C/R motor is producing around 100 more Horsepower. Granted there are other variables in the 2 builds, but I had a 13 to 1 C/R 413 that would run 12.80s at 108, Where as a 440 in the same car 65 Belvedere, EXACT SAME HEADS, (915) and intake, headers, with 10.5 to 1 C/R, would only run low 14s.
