Cal trac ?
69 GTX
12:55 AM
Milo, Iowa
OK guys with cal tracs I have a ? I'm wanting to putt a Dana 60 in my 69 GTX with a Cal Tracs set up. Bars & mono leaf, My question is I don't see shock mounts on their lower bracket. Also does the 8 3/4 use smaller u bolts than the Dana 60? Thanks for the help?
Tim
same u bolts,they use a bolt for the shock
if you go to carquest or autozone, the HELP section has a perfect lower shock bolt for the shock pad for your setup.
