68suprB
Ok here goes- for all you cam guru's:
I have Comp Cams Part # 21-242-4
292 duration
501 lift
Grind # CRB 292H-10
1968 Dodge Super Bee
4 Spd transmission
383 HP V8
Pertronix electronic conversion in stock dist.
Edelbrock 750 CFM Carb
Bored .30 over, stock intake & exhaust manifolds
3.73 rear
My question- is it normal to have significantly higher timing with this cam over the stock one? The engine was rebuilt with this cam prior to me buying it, and the owner had it at only 8º BTDC. It had no power on the bottom end at all. I now have it set at 21º initial with 5-7" of vacuum and 46.8º total at 3000 rpm with 18.5" of vacuum (vacuum gauge hooked to manifold port). After advancing the timing the bottom end power has improved a little along with throttle response but it still lacks alot of bottom end power, but doesn't ping or knock with the high timing. Kinda just stumbles if you open it up fast, then pulls ok once it's wound up. (with this newly rebuilt motor and a 3.73 rear I thought it would be able to smoke the tires just stomping on it in 1st while rolling) My main concern is advancing it too much and damaging something. Would the cam be causing the need for high timing and the low vacuum? It says RPM range is 3000-6200 so am I just stuck with more or less high end power?
Thanks for any input guys, I don't know alot about cams, is this a super agressive one? maybe too much for this motor?
292 duration
501 lift
Grind # CRB 292H-10
4 Spd transmission
383 HP V8
3.73 rear
