Bens69PlymouthSatellite
Can I swap 8.25 brakes to an 8.75 rear end,I was just curious I have heard you can but wanna find out for sure, for the same year 69 satellite,any info is appreciated,thanks alot for all of your help!
The shoes just need to match the drum. Use the backing plate from the set up and order brakes from the donor car for a "For certain" match up. I did this on many cars. Most recently;
A 7-1/4 to a 8-1/4 rear swap that used 9-1/4 brake set up. I just ordered brake parts for a 79 Cordoba. Worked great on a 74 Duster.
Does wilwood make these donor parts or will I have to scoop them up here and there?
8 3/4 has 5 axle flange bolts where the backing plate bolt, 8 1/4 has 4.Can I swap 8.25 brakes to an 8.75 rear end,I was just curious I have heard you can but wanna find out for sure, for the same year 69 satellite,any info is appreciated,thanks alot for all of your help!
