If anyone can give me some ideas I have missed I thank you in advance.
1967 Coronet 440 , 383 , when driving I at times get a strong raw gasoline smell inside the car.
the car can be full on fuel or 1/2 tank it makes no difference.
New tank and sender with correct seal, new vented cap , I have switched intake and carb new mech fuel pump, pcv is new, I have let it run up on the hoist and checked from the tank to pump for leaks,
these 67s have a fill vent from the tank to the filler tube its good and hose's back there are new when tank was switched. { the car had the same problem before the tank switch }.
I have replaced the pump to carb lines also.
The fumes are not there at every drive , just drives me nuts I cant locate the source.
