the rods in a 440 are longer due to the taller block vs the 383. the rods can be used but custom pistons with a shorter compression distance will be needed, not cost effective.
A longer rod can give you a better rod ratio angle but if I were to use the long rods in a low deck, I'd go with a 400 block since it has a larger bore than the 440 and only if I was going to build a wild engine and not a streeter... http://www.stahlheaders.com/Lit_Rod Length.htm
