Ok I have a 1968 Superbee with a 383 Auto. I have replaced the Carb with and Edlebrock 650 with electric choke and just upgraded the distributor with and electric Mallroy.
The problem I am having if I punch it it falls and it face (like the engine cutting out) then the carb does a little backfire I would say and then it goes, but if I am in it a little already it will punch down with now problems. So what would you guys suggest? Also before changing out the distributor I was having this same problem oh and the timing is set at 10btc.
Oh sorry on more thing I am having another proble with not getting a higher idle at cold start-up and have adusted the choke control on the side both ways with no succes and I have checked the voltage which work fine and is fully open at normal temps. Thanks for any help.
