SOLD Carter fuel pump
67coronetman
1:29 PM
Blount Co
Feedback: 3 / 0 / 0
Below you will see a description of this fuel pump I'm asking $75 it's virtually brand-new was not even on the car 2 hours.
Brand:Carter
Manufacturer's Part Number:M6903
Part Type:Fuel Pumps
Product Line:Carter Street Super Mechanical Fuel Pumps
Summit Racing Part Number:CRT-M6903
UPC:724956018604
Fuel Pump Type:Mechanical
Flow Rate:120 gph/454 lph
Fuel Pressure (psi):7 psi
Fuel Pressure Regulator Included:No
Sending Unit Included:No
Inlet Size:1/4 in. NPT
Inlet Quantity:One
Inlet Attachment:Female threads
Outlet Size:1/4 in. NPT
Outlet Quantity:One
Outlet Attachment:Female threads
Gasket Included:No
Wiring Harness Included:No
Mounting Bracket Included:No
Mounting Hardware Included:No
Pulley Included:No
Quantity:Sold individually.
Notes:Natural housing finish.
Description: Carter Street Super mechanical fuel pumps flow 120 gph from 5.5 to 7.5 psi. They contain heavy-duty diaphragms, high-speed "anti-float" springs, large "full flow" valves, and lightweight all-aluminum castings. As with all Carter fuel pumps, they contain a tough, heat-treated lever.
