Brad : That`s great that it worked out. Just a quick question. What is the 4 digit number on the side of your reverse lever, on the mechanism? I see your grip is awfully close to the dash! When Mopar introduced the pistol grip in 1970, they made the mechanism levers noticably longer then previous years & stamped 7174 on the reverse lever, for identification. They did this because the pistol grip handle ,was so much taller, then previous handles & if you have the 69 mechanism, you will be smashing your knuckles against your dash board, on a hard shift from 2nd to 3rd. And it doesn`t stop there, the shifter rods are different from 69 to 70, again to work with the 7174 box & pistol grip handle. Try it and see ,but if your knuckles end up skinned ( they probably won`t as your dash is padded & on the 70 ,it`s hard plastic), you will need to change the mechanism & rods. The first pic is 69 rods ,the second is 70.
