Changing out a 488 dana?
koosh
4:09 PM
CT
Hi guys, knowing nothing about differentials, I am currently looking at a 69 RR that has a Dana 4.88 rear, which I believe would not be good for a cruiser car? Can this gear ratio be changed (and to what?), while unit is in the car?
Thanks!
You'll need to change the carrier to go to anything beyond a 4.10 due to ring gear thickness/pinion diameter. More teeth=larger pinion, thinner ring gear.
Doug
As dvw said you'll need a new carrier unless they used a 4.10 and under carrier with a spacer. You'll need to remove rear cover and look for a approximately 1/4" spacer between ring gear and carrier. 3.54 gears for a cruiser.
It’s not hard to do, but if your lost already, I’d take to a qualified shop to have it changed out. A good 4x4 shop should be able to knock it out in about 1-2 hours.
Thanks for the info guys!!!!
5.7---not lost mechanically, just lost on procedure! :rofl:
If you got a press and dial indicator, your half way there.
Since you’ll be changing everything, no need to check backlash. So let’s gets started.
Mark the bearing caps so you which way and what side they go on. Remove bearing caps.
Pry out the carrier, they can be stubborn.
Take an 1 5/16 socket to the pinion nut with an air gun. Remove the yoke, it can be stubborn also.
If the pinion doesn’t come out easily use a brass punch and BFH. Remove the seal. There are shims on the pinion, don’t lose them.
Knock out the old races, there will be shims under the BIG race, don’t lose them.
Now you’ll need to clean out the housing, get it military clean as you don’t want and crap ruining your new bearings and gears.
Set up bearings is what I use, but if you don’t have them, you can use the old set, just be careful not screw them up when you take them off. On the carrier bearings, there will be shims under those, don’t lose them.
Take a small flap wheel to the old bearings and you want them to be able to slide on/off. Now we can start.
Knock in the small pinion race, now take the shims that we’re under the big pinion race and lay those in, knock in the big bearing race. The small shims that sat just below the pinion yoke splines, install them. Push the pinion into the housing, small bearing up top (under the yoke) thrust washer, yoke and a nut that is not the locking type (just a regular 7/8 fine thread). Do not install the seal yet! Tighten the nut with your impact gun. You’ll want rotational torque to be around 30inlbs. You might need to beg/steal/barrow one. To tight, add a small shim to the ones under the front small bearing, too loose, take one out. Do this until you get 30inlbs of ROTATIONAL torque.
Carrier, put the shims on the same side as you took them off, slip on the bearing and race, drop them in the housing. Tighten bearing caps and Check backlash. Shoot for .007, as things wear in, it will lossen up a bit.
Not at .007, move the shims, take one from one side, and put it one the other. Repeat until you have .007.
Now check the pattern. You want it centered on the tooth, top to bottom and front to back. The internet has all kinds of pics of acceptable patterns.
Once your happy, disassemble and install new bearings. Torque to spec, don’t for get to install the seal and locktite the pinion nut.
This is it in a nutshell, so if your unsure, have a buddy that’s done a few help ya out. It’s just nuts/bolts/shims, not building the space shuttle. You can do it, take your time, ask if ya got questions. We are here to help.
Thanks!
No way you can "cruise" with 4.88 gears....those are drag race only. As these guys are saying, if you pull the rear end cover off & you find a spacer behind the ring gear (likely), then all you'll need is a set of 3.54 gears & a shop to install them. You will need to drive (or tow) the car to a shop that can install the gears unless you're a really good mechanic, then follow 5.7hemi's advice. You top speed with 4.88's is maybe 45-50mph and the engine will be screaming.
You've never driven from Detroit to Columbus with 4.56's, raced at Mopar Nats and driven home? It's an adventure.
Doug
Doug
Close, Doug. Had an 8.75" with a spool and 4.88s in my 63 Corvette roadster. Drove from just south of San Francisco down to Orange County International Raceway near Los Angeles for an all Corvette drag race. I was lagging behind the rest of the guys in my club on the freeways but the on-ramps were all mine...lol.
5.7.....great info thanks.....thanks to everyone!
You can cruze stoplight to stoplight on cruze night...
sort reminds me of the 140 hp corvair we moved a turbo onto- Crower reverse rotation cam and SU carb from a Jag
Could pull a 911 on the proverbial on ramp up to about 55 in a VW bus
