- 1:05 PM
- Nov 21, 2008
- In GTXtacy Illinois
Is there any easy way to change out motor mounts (well, the isolator-the rubber part) without a cherry picker and a car lift??
my right side one is pretty cashed, and since i have the exhaust manifold is off already, i figured i should change it.
i think it would be easiest to take off the mount completely (both sides); then separate and re-install the isolator from there...
only place i see to hold the motor up is a little ear back by the bellhousing on the right side. not sure if that would be ok or not.
i unhooked the trans and kickdown linkages, am i missing anything else??
any thoughts and comments would be greatly appreciated, as always!!! imp_daddy:
