Coelacanth
- 4:09 AM
- May 10, 2024
- Edmonton, Alberta, Canada
With my front bumper installed on the '70 Charger, I set about to install the headlights. I have all my 8 adjuster screws handy, but looking at the headlight brackets like a simpleton, I couldn't figure out the install. I've seen images online showing each headlight bucket installed with 3 screws, then 2 adjuster screws on each headlight bucket into the square plastic nuts pressed into the brackets. I know the buckets are marked for HI/HI-LO and RT/LT but that's not the issue. I can't see how to screw in the buckets. I *do* see 3 large holes in each headlight bracket where the bucket screws would probably be positioned, but there's nothing there for them to screw into. I had everything stored in a Ziploc bag so I don't think anything went missing. What am I missing?
EDIT: I should add that I went through the FSM and although it goes on at length to discuss headlight aiming and to simply remove the trim ring to remove the sealed beams, it oddly mentions nothing about how they're bolted onto the actual car, other than to say not to mess with the adjuster screws. Well duh, many of these cars have had the adjusters and buckets removed...
