Street fighter
I have a 73 dodge charger that vibrates at speeds above 50,it's so bad that I believe it may be causing the rear seal to leak trans fluid. I replaced the drive shaft and u-joints but the problem is still there, I believe it may be coming from a worn out rear end. I had the wheels on the rear balanced but it don't seem to help. could the rear wheels being out of balance cause the vibration? I also sense a noise that seems to be coming from under the car also jacked up car and checked rear end but there was no play or no sign of leaking. need help.
