EngineerDoug
Hello all,
It's yet another electronic ignition question! I've got a new motor running on the Mopar electronic ignition system - all new coil, ballast, ignition box, distributor, and plug wires.
I am fiddling with it to get it running right and probably have more than one issue going on. Note I am still tuning the six pack setup, so the fuel part of the equation may be a bit "off" yet.
So after I drive it around a bit, it starts to run more ragged. Once I stopped I could not get it restarted. Seemed like ignition, so I started troubleshooting the components listed above. Swapped out the control box & ballast but no joy. Securely grounded the ignition box, too. I did find that the reluctor gap in the distributor was too wide (0.014"). Would that be wide enough to cause problems? I know the spec is 0.008".
Out of curiosity I tried an experiment - connected my timing light and cranked the engine. I expected to see the light flash while the engine was cranking, but saw nothing. I get spark from the coil, however. Wouldn't you expect to see the timing light flash? I know I need to pull a plug and check for spark at the cylinder, but shouldn't the timing light be triggered during cranking?
Also, I know my charging system is OK, as it puts out 14.0V. I did connect the car to a battery charger to facilitate these experiments and saw that it puts out at least 16V. Could this be enough to damage the ignition box?
I know these are oddball questions, but I just want to eliminate unknowns or possible clues.
Thanks.
Thanks.
