euroz06
Hi All,
I just purchased Classic Air/original air upgrade kit for my 68 charger (383/original AC car). I'm looking at instructions and parts that I have, and it leaves me with many questions. I was wondering if someone who had done this upgrade could share the pictures from under the hood. Mainly, by the compressor, by the firewall, by the dryer.
The kit that I have has a hose with a high side port (red), and no fitting on the other end (i have a separate condenser fitting). I assume this port goes from condenser to compressor (suction hose?)?
The second large hose (discharge hose?) has a fitting, but no port on one end, and the other end is open. I have a metal evaporator fitting (I assume for the low side, it doesn't have a cap on it). So does this other end goes to the side near the firewall and I add this fitting with a port?
My original system on the low side it has this big metal hose, plus a large hose with some big muffler of sorts. So this big hose (after muffler, on the metal fitting) has a port, where the expansion valve connects. In my kit, I don't understand where im supposed to connect the new expansion valve.
I also have what I think is a thermostat switch. So im confused on how my current system is set up, but i don't think i see it anything on my firewall. So this switch also has a metal line that im not sure where to connect it to. It also has two connectors on it, and im not sure what to connect there or where to connect it to.
I also have pressure safety switch, but there are no instructions on installing this, and I don't see one in my current set up. Do I need it?
