FOR SALE Clone 426 wedge with crossram for sale or trade
biff426
6:53 PM
Middletown, De
Feedback: 1 / 0 / 0
maxwedgeclone.jpgFor sale air cleaners to oil pan
1966 440(426 clone)
bored .30
block was pressure tested ,maged,and decked with plates
brass frost plugs
stock steel crank, turned 10:10
stock rods maged, polished, re-sized and fitted with arp rod bolts Keith black hyper tech pistons
10;1 compression
fully balanced
moly rings
double roller timing chain set
high pressure oil pump
new oil shaft and pickup
comp custom hyd. cam
483 lift 280 duration 233 at 50 114 lope
452 steel heads ported
machined seats and bowls clean pressure test and mag test
resurfaced heads
machined for spring cups and seals
relined and polished quench area
gasket match
flat mill 0.35 cc
comp 4700 cups
comp seals,locks,springs,retainers,lifters and push rods
new mopar rockers
a and a max wedge cross ram with linkage,factory air cleaners.
2 eddy. avs 550 carbs
mopar elc. distributor and ignition
magnum manifolds
very little drive time great street cruiser still in car can hear run and drive it
$6500 BO may trade toward 6.1 Hemi parts
Located in Delaware 20 mins from 95
