I'm getting a clunk noise from the rear when I hit second hard I wondering if traction bars would stop this. Everything mechanically is fine I think it just the rear end slapping please give me some input
Does it have a pinion snubber, S/S springs, ?? When snubbers are adjusted incorrectly you can get a pretty good wallop when the axle wraps enough for it to smack the floor if set too far away. Traction bars are commonly known as "slapper bars" for a reason too! They can slap with axle wrap if they are not adjusted correctly too. The little bumpers should be adjustable and set close to the leaf with tires on the ground. Mopars don't commonly use traction bars however....... A set of Mono leafs and CalTracs would be a nice upgrade for you to perform over the winter. Its a weekend job in worse case scenario.
I used to have a 70 duster that used to bang pretty hard when i side stepped the clutch, stock pinion snubber. Try putting something on top of the snubber like a glob of grease and see if it transfers to the body. Just sounds like aggressive driving to me lol.
Check motor mounts too. The motor torquing uup and then catching will give you a bang that can feel like its coming from the rear. Is this an auto or manual trans? Just a thought. If the mount is bad you usually fell the thud or bang on accleration too, but maybe not. Worth a look i suppose
