sr71mopar
Its a 66 Satellite 383/a833. Did not run when we got it. We had the flywheel turned and put in a new parts store clutch kit. Stock style B&B.
The problem is, when you press the clutch to the floor, something is rubbing on the clutch hub coil springs. I can see the rub marks with a flashlight. I'm assuming its the fingers on the pressure plate. When I back the adjustment off to eliminate the interference, the clutch pedal does not come back to the top. It's down a couple inches and is below the brake pedal. The over center spring is in place and everything moves smoothly.
This is my first mopar with a clutch, but this does not seem right. Any ideas?
