gregs69
Hello,
I have a 69 Coronet with a 440 and 833 trans. I rebuilt the car and just trying to work out the bugs. On the fork, I adjusted the throw out bearing so it did not touch the fingers on the pressure plate. After driving for about a mile, I heard the throw out bearing again. I went under the car and fork pivot is to loose. I did call Brewers and he said I probably have the wrong pivot or the fork spring is bad. I went back under the car and removed the clutch fork and pivot. The spring is to far out and it looks like I have an A body pivot. I already ordered a new pivot and fork. My question is, is it possible to replace a clutch fork when the tranny is still in the car. It came out easy but I know going back together is not always the case.
Any tips or tricks would help.
Thanks, Greg
Thanks, Greg
