Lighthorseman
- 6:59 AM
- May 12, 2011
- Prince Edward Island
Forgive me for such a newbie question, but I'm stumped. I'm trying to convert from a 727 auto to a 4-speed in my '70 Satellite. I have a pedal set, but, for the life of me, cannot figure out how the clutch pedal overspring goes on. Here's what I have:
The spring itself looks to be fairly hefty. I initially assumed that it was to pull the clutch pedal away from the floor, toward the driver's feet. I cannot find any way it would install to do that.
Then there's the little short bar (A). I assume that goes in the hole in the pedal frame, and the "long" end of the spring attaches to it. Is that where it goes? Which end goes where? Is there a clip that holds it in place?
I think I know where the "short" end of the spring (B) goes. I also believe that it attaches with the open part of the hook facing upward. Is this right?
Am I correct to assume that the term "overspring" means that the spring stops the pedal from going too far away from the floor, rather than pull the pedal back toward the floor? Does this mean that springs wothin the clutch will push the clutch pedal toward the driver, and that is the spring to overcome when pushing the clutch pedal in?
If I am completely out to lunch, could someone clue me in? I looked everywhere, but was unable to find any sort of diagram to help me out. Anything would be appreciated.
Thanks!
- Steve -
Thanks!
- Steve -
