Clutch pedal sticking 1967 GTX
Pops1967GTX
7:03 AM
Monroe, New York
Clutch pedal only returns half way. Need to use my foot for full return.Checked springs & linkage. looks ok.
How about the plastic spacers in your z bar..Are they in good shape?Sounds like somethings binding..
Petty Blue 67 GTX
have you changed anything? I have heard of some clutch and pressure plate combos needing the overcenter spring removed. Maybe someone more experienced will chime in.
just got mine running had the same problem. to fix mine all I had to do was adjust the clutch rod alittle more.
thanks ..wrong spring was on ...looks like it was from a A bodie ...
problem is fixed...but at the end of adjustment & need new clutch rod washer..
