Clutch safety switch
Jaymarr65
1:42 PM
Nj
Guys I'm looking for a clutch safety switch # 3488177 or a 2947858. It for a 72 RR .Thank you Jim
:BangHead: I thought someone would have responded by now. I am sorry, I can't help you. I jumped out every switch in every manually shifted car or truck I had as I don't like the extra wear and tear on the throw out bearing, clutch and my leg joints! The switches will most likely only get harder to find as the vehicle manufacturers seem to want to do away with standard shifts completely. That way they don't have to offer variety. Also, they make a fortune rebuilding those 8 and 9 speed trannies!
the one your showing off ebay mounts different,and has the nut attached to the switch,not the clutch pedal frame,also mounts on the inside of the frame instead of the outside on 71-74 cars
