///Matt
68 Satellite. Is there any difference between a big and small block, and/or between a 727/904 for the shift linkage on a column shifted car? Any different length parts, or different linkage entirely?
Car was a 318/904, PO swapped to 440/727. The shift linkage is stock, and has a real hard time reaching park. Additionally, the column display arrow doesn’t perfectly line up to the selected gear.
If they’re the same linkage, HOW do you adjust it? There are no clearly adjustable portions of the linkage, and adjusting the arm at the trans is not a small adjustment.
Maybe the whole column needs to be loosened from its brackets and rotated a bit to help?
