SOLD Complete roof for 68 69 70 Road Runner GTX Super Bee Coronet
Moparparts
5:13 AM
PA
Feedback: 132 / 0 / 0
Complete full roof,structure, and skin for a 68 69 70 Road Runner, GTX, Sport Satellite, or Belvedere, 2 door, hardtop, or post coupe. This came from a 70 B-body, and the skin and structure is also the same for a 68-70 Super Bee, or Coronet back to the center of the sail panels where the quarter outer skins and inner structure attach, but will not work for a Charger. This has been cut full, so installation can be done without any sectioning of internal or external metal. Just needs some final trimming on the ends. The skin is very straight with no dents and no visible dings. There are some small rust holes on the sides of the rear window perimeter. The front is fine. The under side of the skin and structure mostly have just light surface rusting with no deep pitting. Pick up zip code in PA would be 17086. $550
NOW cutting up for pieces Let me know by PM or post if you need any sections
roof diagram
diagram for roof repair piece
Only the internal structure is still available minus the 2nd from the front cross support. The skin is cut
The front crossmember and pillar sections are no longer available so the only pieces remaining are the two rear crossmembers and the sail areas. PM or post if you need any of those pieces Thanks FBBO
updated pics with remaining pieces
Here are updated pics. This is all that is available any longer. Thanks FBBO.
Getting close to hauling in a load before buried in the snow if anyone needs any pieces post or PM
Its still available if anyone needs any pieces post or PM
Roof pieces
I could use the roof sides cut 12" in from the side rails...interested in cutting and boxing up? I am making a full size side view garage wall hanging of a Road Runner. How's a $100 bucks + ride?
I just sent you a PM check your private messages
