fatecaptured
I have posted in other threads about my 72 rallye w/1971 440 HP. Now i'm getting into it. I decided to do a compression test on all 8 cylinders. I'm going by the "72 dodge service manual CD Rom". Although it said to tighten the intake bolts to 50 foot pounds (which I didn't see till after I completed the test). I could be wrong, but I don't think that makes a big difference.The motor hasn't ran since i've had it, and previous sell said it ran for a short time when he was checking it out. I wanted to check the condition of the engine before trying to start it. Anyways here's what I came up with:
Drivers side (front to back):
1). 110 lb's
2). 110
3). 70
4). 100
Passenger side (front to back):
1). 60
2). 85
3). 50
4). 85
Now the manual says for a 400/440, that 100 pounds should is where they should be and not vary more than 40. But it also says"Many conditions which are difficult to control cause variations in compression readings. An engine should not be disassembled to determine the cause of low compression unless some other malfunction is present".
So what the hell do I do then? LOL It goes on about changing plugs and wires . This is all under tune up procedures. But with the big difference in readings , I can't help but feel like there's something fishing going on.
Any thoughts???
1). 110 lb's
2). 110
3). 70
4). 100
1). 60
2). 85
3). 50
4). 85
Any thoughts???
