Console Clock help
ChargerRTguy
3:30 PM
NW Indiana
I have a console clock that I want to use and I'm not sure of the wiring. It has a purple wire, gray wire and white wire. I cannot find any wiring diagrams, hope somebody can help.
If my memory Serves me correctly it's a 66 year clock with EL lighting , it should be purple-power ,gray-ground ,white-light. Very simple to check pop the clock open see we're the wires connect too.
White is ALWAYS EL. If it were bulb, it would be orange.
If you need pics, let me know. I have both.
if it is indeed a 66 Charger clock, you won't be able to see it light up without special power pack that turns 12v into 250v AC for the EL lighting.
Thanks again for the help. I did take it apart after trying to get it to work. It must be a 66, the white wire goes directly to the hands, for EL. The purple to the case and gray to the clock. I lightly oiled it, got the clock to run if I manually work the solenoid, cleaned the points, but still nothing, maybe my old train transformer does not have enough power for the solenoid ?
the train transformer should have enough power...clock probably just needs a new set of points...or the winding's in the solenoid are fried
you could try connecting it to car battery, but I bet you get the same result
I have a 66 clock (EL) in my 67. Just tapped off the white wire under the dash for the radio and ran a seperate wire down under the console.
But mine was frozen the same way. I sent it away and had quartz movement put in so I never had to worry about teh points sticking again.
You have to get it fixed anyway, for a few extra bucks, THE way to go! And it's inside, you'll never notice the difference.
