roadrunner400
Ok guys. Here’s the issue just finishing up a 71 satellite. She cranked and started prior to me messing with getting lights and signals and installing neutral safety harness. I got some turn signals then no brakes etc…. I went directly to grounds fiddled with those lights got better. Installed harness for NSS then dull lamps turn signal relay no blinky blinky. Removed NSS harness. Blinky blinky came back. Brake lights work. Put a turn signal on and hit brakes turn signal works other brake light pulses with turn signal. That one issue. Went to start car no crank. Meter on dash shows battery discharging when in start position like a load is on it. Over ride battery and solenoid with button starter she cranks great. I thought starter relay was bad changed it same result. Any suggestions welcome. Thanks Mike
