Start by disconnecting the battery next disconnect amp gauge wires and instrument panel connections along with speedo cable. Next remove the instrument panel to dash screws and probably have to lower the steering column for clearance. Once you have the cluster removed you can the remove the bezel from the cluster
by remove the screws at the rear of the cluster. If I missed anything someone will chime in.
