64Belvedere
What is the best way to get the dashpad off of my 65 Coronet? Is it bolted on or clips that pull out? Is the 64 dashpad attached the same way? Thanks.
I had taken the pad out of my '63 Ply some years ago for Just Dashes to refurbish and will have to remove it again as a bubble developed where the adhesive broke down so I can re-adhere it from the back. I don't like the tip I got about using a syringe to poke through with an adhesive. My memory is foggy; but I believe I removed the glove box compartment and the radio to access the connectors; much easier to do and maybe necessary to reach all of them; but could be different given the year. I'll be finding out when I get to this project on the long list!What is the best way to get the dashpad off of my 65 Coronet? Is it bolted on or clips that pull out? Is the 64 dashpad attached the same way? Thanks.
