If she is just going to wrap it and not recover it than you can use HD spray foam to fill the hole and cheese grater file to file it down to the level of the original vinyl. For the cracks you could try a 2 part epoxy and then place the part under a board with weights or clamp to get it as close to original form as possible. Once the epoxy sets up file down any remaining high spots.
