Both...THANX!Removal from the car? Or disassembly of the dash?
Or both....
First thing the front glass and gasket have to be removed.....Second disconnect bulkhead connections and bulkhead unit and the connections behind the kickpanels. Disconnect AC/Non AC vent/ac hoses. Remove vent cables underside of dash. Loosen the two lower bolts of the dash frame to boot but do not remove. The two threaded studs for the steering column remove those as well(makes life a lot easier) Remove the top bolts of the dash frame. Then pull the frame towards the rear using then you expose the vent cable and remove them from the heater box if AC then you can remove the hoses from the controller on the dash. Once all things are disconnected pull the dash up to clear the lower bolts and remove as one complete unit. Install is the reverse...
The worst part of a non rally dash is the switch panel and pad...The rest is easy...Both...THANX!
