LowDeck451
Was wondering if anyone could recommend an economical Dial Bore Gauge in the $250ish range? Any particular brand or model you prefer? Planning to use the mic-over method to check clearances. Thanks!
Interesting. Yeah, I'm not against using plastigage, probably will. Years ago I borrowed a machinist buddy's inexpensive bore gage and I liked it, just can't remember the brand. Thanks.Most of the inexpensive ones will dig into the bearings. Plastigage is a really good way for most guys to check clearances.
I agree, if I wasn't sure of a shops work, I would check it before I leave, they should not have a problem throwing their gauge in your holes 3 of 4 times each bore. The biggest thing with putting engines together is the machine shop, its like the painter cant do a good job if the plaster didn't.Engine assembly/checking the shop's work to be on the safe side. I have mics and snap gages, and the other tools you mentioned. Thanks.
Yeah, it's been awhile but it seemed like I was a little inconsistent with the snap gages, then borrowed my friend's bore gage and could repeat dead on. Anyway, thanks for the input guys.Yep I use a fowler and it works great for the cylinders, I wont use snap gauges on bearings I just never get a good reading, I use a inside mic on the bearings and then use a outside mic to measure the inside mic.
