dcoland70RR
Hello, So I am by no means a greatly experienced fully experienced mechanic. But, I have done many many things over 20 years to cars. So one thing I have never worked on a vehicle is a rear end. My 1970 roadrunner was leaking at the differential. After some investigating and some info from a mechanic I pulled the axles slightly out and removed that very heavy gear assembly where the cover is attached from the front. I found no gasket, only a small deteriorated amount of silicone there. Cleaned it all up and put a new gasket on and after that big job to re place a 4 dollar gasket, NO LEAKS< Perfect.
This is where I need help. SO while the gear housing assembly was out I twisted the posi unit to the left and right by holding the input area that the drive shaft bolts to. I was able to move the input shaft a small maybe quarter of an inch to the right before the gears would start moving and the same to the left. So I ASSUMED the gears are worn out from being likely original, almost 50 years old. I took the beauty out last weekend on 2 different days for over an hour cruise and after about 40-50 MPH I am getting some odd vibration feeling through the drivetrain that appears to be coming from the back of the car, like the rear end. But not certain. I am thinking since the car has a recently balanced driver shaft with new joints, new leaf springs and shocks. This is most likely the sign that the rear end needs new gears?
If it is most likely I need to rebuild the gears in rear end andy brand recommendations? Do I need new axles too? Or how to check them?
I appreciate the help because I enjoy figuring things out with help here versus paying a mechanic from a shop a small fortune to do this.
