Disc brake conversion on a 68 coronet
mopar magic
New Member
8:51 AM
ft lupton
Hello,
Can anyone tell me if i could use the spindles off a 1975 charger on my 1968 coronet to set up for disc brakes??
HELP,Thanks
If I recollect correctly they wont fit. Call SSBC and get the 4 piston set-up to fit your factory spindles.
If what you are referring to are the tall spindles then yes you can if you use an aftermarket UCA from Firm Feel. They told me that the upper BJ sits in a better spot to deal with the taller spindle.
