ultramag870
Ive got a 69 gtx with manual brakes im wanting to convert to disc.. What will swap what year will work and what kind swaps.. Or should i spend the money for a conversion kit
Just the spindlesWill i have to swap a arms? Or just spindles
GA66- what hoses did you use? I've got Cordoba hoses on mine, but I'm not sure the banjo hole is lined up.
Are your calipers to the front or the back? mine are to the back because of a sway bar.
Thanks.
Thanks.
having a B-body myself ('68 Coronet) with the same question, I cant help but wonder if Cordoba brakes will work on my car. each article I read says something different, some says change UCA's, some say the spindles wont bolt up, some say they're a bolt on.....it gets a lil confusing lol
