Check Dr.Diff, or maybe the Ram man. The latter seems a bit pricey. Salvage yard diving may be an option.hi Guys.. I'm looking for disc brakes spindles for 66 to 69 B-body. any leds would be greatly apprecaited.
Correct, that's what's on my Belvedere with the 11.75 rotors. Forgot about that.Just a heads up, I used spindles from a 73 RR on my 68 RR. ruffcut
yes.. i have that on my car now.. just want to put what came with the car back then..Just a heads up, I used spindles from a 73 RR on my 68 RR. ruffcut
thank youCheck Dr.Diff, or maybe the Ram man. The latter seems a bit pricey. Salvage yard diving may be an option.
You say "closest to OE", prior you said you want to put "what came on back", so are you restoring it or not. And spindles don't have calipers, 4 piston or otherwise.LEED Brakes seem to be the closest to OE specs.. it has the 4 piston Cal.
