Hard to believe even those are becoming scarce. Mancini is the place. To the OP; make sure you get the right one. If you are working with an MSD distributor, the adapter is a little different.
I ran one for years that was originally from a 440. It had scribe marks on the shaft which matched a 383 length. My friend duplicated the milled end and cut it down to length.
