Distributor Specs?
493 Mike
2:22 PM
White Cloud, MI
Hi fellas, I am converting a 1982 Chrysler from Lean Burn to older style ignition. I have bought a conventional electronic distributor on E-Bay and I can't find any advance specs in my manuals. I appears to be a 1973 model, possibly form a truck? Thanks for any help!
Mike
Send it to
Mike
Perhaps send the distributor to @Hallifaxhops with your specs/requirements and he will set the advance curve to your needs. He's located in Pa and is a subscriber to this form....and is an expert in Mopar ignition.....
BOB RENTON
Send it to
BOB RENTON
All I need is specs from a Motor manual. I just don't happen to have the manual I need. Thanks.
Mike
Mike
If you don't have what you need, then you have nothing....except, perhaps, intentions......just get it done correctly, by @hallifaxhops rather than hack at it.....just my opinion.....
BOB RENTON
The lean burn ran a locked out distributor that the computer controlled the curve and dwell on. To curve a dist to say a advance distributor you really need the motor internal specifications and what carb you will be using after deleting all the lean burn parts.
