Dizzy pickup coil
blackblazer717
2:48 PM
chelmsford MA
Whats the spec for adjusting the pickup coil? On the dizzy. Between the reluctor wheel and the pickup? Thanks. its for a RB if that makes a difference
Or an old wrench might tell ya to use a book of matches to set the gap.....
Thanks y'all, i knew not to use a ferrous guage. Magnetic fields are rediculous in there. ThNks again guys
You can also adjust down to .008". No matter what make sure you check every point on the reluctor for consistent gap.
