Do these parts fit?
Michael_
2:17 PM
Germany
I ordered this bracket right here:
https://www.moparshop.com/Online-Sh...zeugen-mit-4-Scheinwerfern-mit-Montagewinkeln
Its described as "for mopars with 4 headlights".
So i thought it would fit my 69 charger.
When i ordered there was a picture of 2 brackets and sold as "pair".
But i only got the RH Bracket. I contacted them and they corrected the description in the meanwhile.
I noticed they only sell the RH Bracket, not the LH Bracket.
On google i found the manufacturer of these brackets:
https://pgclassic.com/223-rh-mopar-1971-plymouth-cuda-rh-headlight-bucket/
https://pgclassic.com/223-lh-mopar-1971-plymouth-cuda-lh-headlight-bucket/
They clearly state its for a 1971 plymouth cuda.
So i guess they DO NOT fit my 69 charger and i have to buy this whole assembly?
http://www.autometaldirect.com/amd-grille-headlight-support-oe-style-68-69-charger-p-248.html
My question now basically is:
Do the pgclassic brackets fit my 69 charger or not (i guess not?) and if not do i have to buy this whole AMD assembly or a similar used part?
Hi Michael,
What’s up with you’re head light support ? Rottet out or bend it ?
I from Germany too, and if you need I have a full Original grille Headlight support in my storage .
Best regards from Main Spessart Steffen.
Mine is fine.
But i bought a set of LED Headlights and i've been told there is cutting involved to install them.
Im not sure if i even want to install them yet. But if i do, i do not want to cut through the original sheet metal.
So i thought i would also buy the sheet metal and store it away. Just in case.
I also contacted pgclassic regarding if it fits or not, but didn't got a response yet.
