Door Lock Hardware drawing
Jam72
8:35 PM
Sicamous BC Canada
I have replaced the key lock cylinders in my 72 Charger SE. Unfortunately somehow the right door has locked shut and I cannot open it. It appears the lock pull push rod is floppy so not correctly fastened down below. It goes down and up but does not do the job. Does anyone have a drawing that shows the interconnected parts? The manual does not include the details. The key lock connections appear correct, however the latch will not open that way either.
Congratulations, you get to take the inside door panel off to reach all of this stuff. Good luck, it can be a real pain
I’m also changing the door locks in my 1972 Plymouth Satellite Sebring Plus - and yes, it is a pain!
