mopar4don
I am getting ready to put door skins on and was wondering if I should (after epoxy priming the inside) apply some type of a sound deadener like lizard skin to the inside of the skins.
Also when I go to bend the outer lip over should I plug weld it like the factory or would it be better to use a panel bond?
It was recommended to me to use 3M 8115 panel bond and weld the corners. Apparently the panel bond will give a corrosion resistant seal also.
Don
Don
