Driver’s side door window is stuck in closed position!
Brian Lontz
1:46 AM
Eugene, Oregon
Hi, just wanting to know the steps to take to resolve a stuck window on driver’s side door window. It’s stuck in the closed position. Do I need to pull the panel off & lubricate the regulator? What lube to use? How to do it? Not a clue here, !!
Any help would be much appreciated.
Brian
Take the panel and see what the issue might be. Could be a roller jammed up.
Steps: Open door. Pry off inside door panel. Observe conditions inside door, glass regulator and track. Return here, report observations, await further instructions.
The only 2 times I've had a window completely stuck, was due to the forward edge seal bunched up in the channel. The whole assy. has to come out for that.
Brian
Sell the car.
