66 convert
I am doing a conversion on my 66 coronet convert.I purchased the distribution block with the prebent lines to the master from inline tube.I am using a reproduction 809 master cylinder.The distribution block was suppose to work with existing brake lines but did not.The right side brake line had to be made.The lines to the master did not work either.The tube nuts that connect to the master are the wrong size the lines appear to be bent for a power brake car.My car is a manual car.Does anyone out there know what size tube nuts are needed for a 809 master cylinder?It sucks when you pay extra for parts that are suppose to bolt on to existing and nothing works.
