FOR SALE Eagle 4.500" Stroke 8 Bolt RB/Hemi stroker crank with 2.200 rod journals Salvage
Hemirunner
8:40 PM
Down South
Feedback: 17 / 0 / 0
Here you go guys, an Eagle 4.500 stroke RB/Hemi crank with 2.200 rod journals. We had a cylinder sucking oil and this crank didn't survive drag week. If you want to have it welded up and reground, here you go. I'm going to an entirely different combo. It had .005 TIR on the center main so once it's welded, it'll need mains and the one rod journal ground. $250 shipped to your door from IL in the lower 48. Does not include the flex plate.
PM me here.
I suspect that there will be a wide range of varying costs depending upon where you're located. If I were to guess, I'd say $200 to $300 maybe?
